Aquarius V3, from the original a couple of years ago and have been perfectly satisfied thereafter. The V5 looks very smart and I’m sure represents an incremental improvement but I just can’t justify the price .
And I don’t think Isotek et al make anything larger than a 6-way device although I understand the current products may be daisy-chained, although that’ll quickly move to silly money .
That’s what I found Osiris… 10 way blocks seem quite rare
I chose the Olson because it’s hand made and wired in the UK…. Ok it might not be a ‘hifi’ unit but I’m ok with that as it seems solidly built and didn’t cost too much either
It’d be good to hear your thoughts on the quality of the construction etc, and sound quality and any improvements over that which you have been using to date.
The quality of the construction G5211 is extremely good on the Olson, all hand wired and soldered where necessary
I’ve not yet installed the block but will do later today sometime…. I actually don’t expect any improvements in sound but I just like to have a block that is solid and very well made and doesn’t have the word ‘hifi’ in front of it
I thought there was a little more instrument separation and smoothness in the treble with my modified Olson (Over the shoddy Matrix 2). I replaced the cables inside with 4mm instead of the 2.5mm ones they use.
