Powering the NCV TT FROM the 332?
I remain confused about how the 332 can power the Naim serried 300 phono stage without the PS. Does Naim supply a cable ? If so which box includes it and what cable?
https://media.focal-naim.com/dam/nvc-tt/notice_nvc_tt_npx_tt_web.pdf
The NVC TT will have the 8-pin DIN lead you need. It is a Type 1 Power Supply Cable. There is also a 5-pin DIN lead if you power the NVC from an NPX TT.
My NVC TT is powered by the 222. The cable comes with the NVC TT phono stage and works exactly the same way with the 332.
I saw That and did not understand it.
If you are using the NVC TT with the 332, and not with the extra TT power supply, you just connect the NVC to the 332 with the 8 pin lead. This provides power to the NVC and also takes the signal to the 332. So just the one lead does everything.
Hi HH. Naim supplied 8 pin, I think.
Yes, it comes in the box with the NVC TT.
Well eventually I will replace my MM with a MC, but since my MM has only 200 hours. I can wait.
Thanks. I have ordered the 332/333/250/NCVTT I am trading in my SN3:NDX2/XPSDr.
