Primare users, Qobuz not working?
Before I do a full system reset on my NP5 is anyone else having issues with Qobuz?
It won’t load anything at all when I select it. Apps in iOS and Android the same. Qobuz works fine on my Atom so not a connection or subscription issue.
Bruce
Yes and no.
A few months ago the app started acting strangely.
If for example I selected a favorite album, I can play any track, but if tried to go back to the list of albums, the app jumps back to the start.
However, it coincided with a major software update to my phone operating system.
Using an older TLC mobile and Samsung tablet it works as it should.
Just checked and Qobuz works fine the old mobile and tablet.
Thanks. Not sure this is the issue as all my devices (I have tried 2x Android plus an iPad) don’t show anything. I will do a hard reset later.
Bruce
Who said streaming is so much more convenient than playing cds?
Yeah. CDs always played perfectly, never got lost, damaged or deterioated over time did they? They didn’t need loads of storage space and they were easy to search.
Every medium has its limitations. I only use Qobuz to listen to new music before thinking of buying, all the downloads are on the NAS anyway.
Bruce
PS Sorted with a full reset.
