I bought 3 Muso-QB 1st gen. in July 2020. All 3 are wired to the LAN so I just need the WLAN for the Naim app and I enjoyed especially the multiroom feature. I uploaded all my CD’s to the Synology media server with the AIFF format with a bitrate of 1411 Kbit/s and a audio sample rate of 44.100 kHz. When I open the Naim app and choose the UPnP icon, it shows my DiskStation and I can choose music by Folder or album etc. I choose what I want to play, then select the Naim App Now Playing screen and touch the multiroom icon to let the music play synchronically in 3 rooms. It worked perfect. But I’m feeling a bit desperate because since I got the .23 release of the Naim app on my Android (ca. 10 days ago, but this might be a coincidence and the problem has nothing to do with the .23 release) there is no more a multiroom icon when I select the Now Playing screen. The UPnP brings the same screen as in Analog input. Nothing about a multiroom icon. Just the volume slider, that’s all. And yes, the multiroom function is activated and still works fine with radio or USB or Spotify. And I had no changes in my network at all. I read a lot in this forum and I rebooted all components of my network. It doesn’t work anymore like before. Any help would be appreciated.
Basically I think you’re saying that your multiroom icon has disappeared?
I just checked on upnp on my Muso QB2 and QB1 and all work as they should (apart from not being able to independently control their volumes, only as a group)
I reinstalled the Naim app already several times and also deleted all data doing so. Something must be wrong with the Naim app. Now I just found out how I still can get the music played on multiple QBs. I first choose a radio station and let it play in multiroom mode on multiple QB’s because here I get the normal multiroom screen. Then I change to UPnP and choose some music and it will be played on multiple QB’s although there is no multiroom screen, just the Analog input screen. Still it’s not what I expect because I don’t have the random access or replay icons.
I should add I’m using my iPhone 11 for the app. It seems there may be an issue with the Android version as mine on iOS is working OK.
Hi @Bmettler
Can you get a support ticket raised to our support desk with as much info as possible regarding:
- Versions of UPnP server used.
- Phone & Android version its running
- Code version running in the Qb’s (I assume v4.8)
I spent 5 mins trying it here but couldn’t replicate the issue, so there must be some other factors in the mix that breaks it. If possible see if using a different UPnP server works (eg. use Asset running on a PC as a test).
For reference here is mine playing an AIFF test track (it has no artwork in this test track).
Best regards
Steve Harris
Software Director
Naim Audio Ltd.
Hi @Stevesky
There is already a ticket number: 129331. But I don’t know how to add information in there. I sent the following information to support@naimaudio.com but then a new ticket number was raised.
Here some info you asked:
My phone is a Xiaomi Red 7A with Android version 10 QKQ1.191014.001
My UPnP server is the MediaServer package from Synology on a DS1511+ with DSM 6.2.4-25556 Update 2. The mediaserver is responding well and playing the music on a single Mu-So QB but just shows me the Analog screen instead of the multiroom screen. If I choose first Radio and multiroom to let it play on multiple QB’ and then change to UPnP to choose some music, it will be played on multiple QB’s.
I understand that I have to use the Naim app to get the firmware version of the Mu-So QB’s like written in the product manual. If I run the firmware update routine it searches for 1 minute and then leaves the update screen and just goes back to settings. I get no information.
Hi @Bmettler
Thanks for the extra info. After some more experimentation the issue has been replicated here.
I’ve raised it as a Jira to the apps team and will discuss with them next week when the office opens. We’ll aim to get this fixed in the next Android app service release.
Steve
