Secondo screen
Notice
Full Playlist. Impossible to add other tracks.
Those are Asset (or other media server) playlists not Naim ones.
Excuse me, I donât understand, what can I do ?
Youâll have to get on to Asset - it is Asset isnât it?
I donât know, I used Naim app
What UPnP server are you using?
Western Digital MyCloud
With Plex as Media Server?
Hi, that is where you expect to see playlists created on your UPnP server, which is on your WD NAS. If you create playlists on the Naim app, they normally appear in the app home screen, as in Guinnless screenshot above.
How long are the playlists?
Twonky
More than 500 tracks
You may need to go into Twonky on a PC and delete them from there.
Thatâs what I thought! Even if you store playlists that are longer than 500 tracks, you cannot play then using the Naim app, as it has a limit of 500 tracks in the play queue.
If you navigate to the playlist and try to play it using the NDX remote control/front panel display, what happens then?
The NDX plays them all
Then that is your answer! The app has a limit of 500 tracks, but once you have started play using the remote, you can return to the app to see whatâs playing, control volume, etc.
Many thanks for your patience, I found the playlists on Twonky. I am not able to delete them, I will do a search on the web. Best regards.
Thanks a lot for your help, I almost solved the problem. Best regards.
