Waiting delivery of a used 202. Lots of helpful advice on here, but one quick question - there’s no remote supplied with the item, is it possible to access programme mode without one? If not, which model should I buy?
Many thanks.
I think that you need a NARCOM 4 or 5.
Thanks Graham. Thought so, but wanted to be sure. There’s always something, isn’t there?.
Do check before you buy, unless someone confirms this.
