Puritan 156 review
Whenever I glance at this thread title, I always think, ‘Oh, there’s a new Alfa.’ :wink:
Yeah, let’s hope the Puritan is more reliable than Alfa Romeos. :muscle:
I’m in the US and I’ve got to say I’ve never had this kind of humming issue. Well once. It was caused by a Dac emitting lots of Digital ground noise that was getting picked up by my preamp. I just find it peculiar that Naim stuff seems so sensitive to what ever. I had a SN2 with HCDR and it was quiet. I have a Muso 2 that is totally quiet. Maybe there’s less noise on our AC lines here? I’d be curious about other folks in the US
Got a bit carried away this weekend…saw a 156 on ebay at a good price and my transformer hum is so loud I thought I would give it another go…
I’m going to have to eat toast for the rest of the month and not have the heating on, but HiFi is HiFi :rofl:
Cash flow is on fire! :smile: Red wine and HIFI interest is a great combination for the trigger happy ones like us :smile:
I also use the Ground Master City, on the digital side of the network here (router > Meraki modified MS220-8P).
Puritan also recommend them for use on the analogue side of the chain when a grounding rod installation isn’t feasible.
I have Puritan PSM156 earth > Ground Master > 2.4m copper ground rod in bentonite
and
analogue component signal ground > Route Master > (separate) Ground Master > ground rod
There are transmission lines <100m to the property and for me the above removed the variability when listening at different times. Recommended.
Power amp is plugged direct into the mains (separate circuit breaker), it is not normally recommended to plug an amp into any type of conditioner due to the limiting effect on dynamics. Of course YMMV, however that was my experience.
The 555PS for the NDX2 is connected to the PSM156 and definitely benefits. DC component on the mains makes the toroidal transformer hum and realises that beautiful calm and space associated with low noise floor.
PSM156 C20 IEC inlet was changed to the Furutech FI-33 NCF pure copper type as were the IEC connector and mains plug on the Puritan power cable; can’t say the latter made any appreciable difference.
I know, alcohol was definitely involved this weekend in large quantities…
hehehe, not quite that much but enough to spend all my money! :joy:
I’m about to list a Sarum T full loom so I should end up about even overall :+1:
Good man. You’ll soon have full 500 system. You’ll remortgage the house and live your dreams ! :muscle: :smiley:
Well…I am still watching a 555DR on eBay. A few more beers this afternoon and who knows what might happen :joy:
Can you elaborate on the difference with the Furutech inlet change?
Which IEC and mains connector did you put on the mains cable? Was it also the 50 NCF? Was it the Puritan Ultimate that you put these on?
I think as you’re selling all the other cables on it is worth seeing what full Super Lumina loom does on your system.
10 hours to go :beers:
:crossed_fingers:
So…I can only afford to put in my best bid on either the 555DR or the SL Din-XLR cables…I could try doing both, but if I win both I will be in trouble…what do you reckon I should shoot for?
We went source first. Still haven’t gone back to SL between pre and 300.
In your case 555PSDR every time. Your source is the bottleneck in your system right now. It’s out of balance. The 555PSDR or even an XPSDR will even things out. Former is better and good investment later down the line if you want an ND555.
You need to focus on your source.
The Din to XLRs can come later. You should get those too once you have sold your old kit.
555PSDR is your best choice there!
Thanks both, that makes sense and was my gut instinct. The last one on auction went for just under 4k which is out of reach for me, but you never know it may be a quiet Sunday on eBay :crossed_fingers:
That’s what they cost, auction or not. Other thing is to sell your other gear first then get one.
