If you connect a turntable to a Qb using a phono cable to the jack plug on the qb is there a limit to how long the cable is? Can the turntable be on one side of a room and the qb on the other about 12 feet apart for example?
Presumably distance is good for isolating the turntable from the vibration of the speaker?
Iād say it will be fine if its a line level signal fro m a turntable with a built in phono stage.
If its a standard turntable and your phono stage is next to your Qb, then possibly not.
Perhaps you could have just added this question to your existing thread rather than start a new one.
