Hi guys,
Nice easy one…
Do the gen 1 grills fit the gen2 Qb’s?
Cheers!
Hi guys,
Nice easy one…
Cheers!
They are sold as 2gen accessories, so maybe the clips changed from first to second generation. See if you can get a close up picture of both without grilles.
Physically the grilles are interchangeable between first and second-generation Mu-so and Qb speakers.
HOWEVER… the material used on Mu-so 2nd Generation/Mu-so Qb 2nd Generation is more acoustically transparent, so you do risk a tiny performance hit if you put a 1st Gen grille on a 2nd Gen unit.
Good to know.
yes, and vice versa too.
Thanks all.
