Is it possible to assign established playlists from my Apple Music library to my favourites presets on my Qb2? If so, how do I go about it? Thank you.
As far as I know, only spotify playlists are supported!
Piet
You cannot as it doesnt have an Apple Music Integration. Apple not great at opening up to others, Sonos is about it.
Thank you
Thank you for the information
