Qobuz drives me nuts sometimes. Just wanted to play Lizz Wright’s album Shadow in Hi-Res. So, I searched for Lizz Wright and selected the list of albums. Huh…album was not there.
I knew that I added the album to my library when it was released. So, I selected albums from my library and there it was.
I than checked the Qobuz download store web-site by searching for Lizz Wright and there I also found the album. But than I selected discography to see all albums and it was gone again.
Argggh…Makes you wonder. Do I trust streaming services with my music?
It’s the search function within the qobuz app that is broken. You have to search by artist and if it’s not there, try again by album name.
Another trick is to look in the “most popular” section where you sometimes see odd tracks from the album.
The metadata in qobuz must be correct because roon can find it.
Yeah, I can find it. It is just annoying that albums are not visible in the discography. In this case I know the album. Sometimes I am just exploring and I want to see the full discography with all available albums. It is just unreliable. This is not the only issue. Tracks disappear sometimes or are suddenly greyed out and can’t be played etc.
yes it can be very frustrating - it seems such a simple thing - my workround is to select another album and then look at other albums list which often has the album i am looking for
