Qobuz desktop app - did the UPnP feature disappear?
Have not used it for a while, but have decided to download purchased content to an external drive (again).
Am I confused or did it used to have some kind of beta UPnP service, can’t see that anymore? It seems to download in FLAC now (no format selection still which is a shame), maybe it always did.
I have used the Qobuz desktop app for windows to download purchases, although not for a month or so. But I recall that it’s quite difficult to find the place where you can define the download format, but it is there if you persist. Last time I used it I wanted to download in both Flac and then Wav and it did prove possible to do that. Highly irritating though.
All format options are there, just as they always have been.
It is till there. Bottom of the app, in the audio output section.
That’s on the web though isn’t it?
Still nice to get all format options there but I ‘ve never found a firmat iption in the desktop app which is very fast and slick otherwise.
The reason I’ve not used it for a while is that it deleted all my downloads once in a much earlier version. It shoul only delete cached non-purchased music if you sign out but it did more than that - hopefully a bug that’s fixed.
Odd, I’m not seeing it at all.
