Qobuz downloading issue
Since January, perhaps a bit before, if I download an album from Qobuz there is no metadata
I am not prepared to type it all in manually, so contacted them in February, was told they knew about the problem and were working on a fix.
To date - no fix - contacted them again this week - still working on it ?!
Does anyone else have this isuue?
Most annoying!?
What format are you downloading.
They used to have issues with WAV, but not FLAC
I download FLAC
Just use MP3TAG app. All done in under a minute.
Recent flac downloads have been absolutely fine for me. I’m using the Qobuz downloader on iMac.
I found it more reliable in the end to download from the qobuz app.
Thanks - dozy me never thought of that, will give it a try!
