I’m having a senior moment and can’t work out how to get Qobuz favourites to show on the main screen of the Naim App. I have options of presets and radio but not Qobuz. Turning Favourites on under input settings makes no difference.
If I go into Qobuz I have a My Albums section, but I have a feeling it’s possible to get them on the main screen.
If anyone has any ideas, I’d be most grateful.
AFAIK, you can only add individual albums or tracks to presets.
To do so, tap the three dots to the right of the album or track and select “Add to favourites”.
If you select your favorit track or album by pressing the star button, your favorites will be displayed under album or track in the Naim App
This is the screen I thought they would appear on, but they don’t.
You need to go to Input Settings > Qobuz:
If you were in the room, I’d kiss you. Thanks!
You’re welcome. No kisses required!
Hollow
April 12, 2024, 10:05pm
8
You should try changing your Radio Paradise feed to the FLAC stream from 320k, available in hidef folder in radio menu
Thanks for the tip, I didn’t know there was a FLAC stream. It shows in the search as 1000kbps, which I didn’t know was lossless.
Hollow
April 13, 2024, 8:16am
10
JB Radio 2 is another good one in FLAC with excellent sq, also available in hidef folder
Thanks, I’ll give it a go.
I’m listening to the RP Mellow Mix in FLAC and the SQ is wonderful. Thanks so much for the tip.
Hollow
April 13, 2024, 12:12pm
13
good stuff, I actually think the mellow mix sounds better than the main one, maybe it’s just the genres of music that does it, I find the main mix has really deteriorated over the past few years in terms of music
I feel left out. Why do I not have the option on my input settings fir Qobuz?
Apple/Android disparities possibly?
I use a Samsung Galaxy and, like you, do not have that setting available.
Android here too. I’ll live without having that functionality rather than having to use an iPhone (work phone is an iPhone ).
I have the functionality, just not that option in settings.
My favourites are under ALBUMS on my app homescreen.
davidf
April 15, 2024, 11:25pm
18
Your Talking Heads tune is my favorite
Incredibly well recorded as well
Was quite effectively used in the movie “Wall Street “
