I changed my password recently at Qobuz and now I am able to go to the Qobuz web page (web page in the browser / download store with new password) but neither the Qobuz app nor the naim app would let me in.
Wrong username - password combination.
When I go to login in the app the webpage opens and it tells me that I am logged in and again the login window of the app appears - constant looping.
I suggest logout of Qobuz in the Naim app and then also logout from their web page and from the Qobuz app. Restart your device then login the Qobuz app with your new credentials and then do the same with the Naim app.
Keep passwords to letters and numbers only; occasionally depending on the platform, symbols such as % and & within passwords can cause upset.
If symbols are mandatory, an underscore “_” usually works.
You may have to let it all time out. The password changes probably take time to propagate through to all of their servers. I would leave it for 24 hours, then try with your last password.
You could be in a situation where it depends which server you are using as to which password it expects. That should all sort itself out if you leave it alone for a while.
Thanks for your support very much. I leave it alone. I am (if this happens) initially a bit worried that there is something cracked by a hacker bastard.
All safe!
