Keep getting this message.
Login works for Qobuz App and website.
Have you changed your password recently, and does it contain any symbols such as ! or #?
No, as I say the exact login details work for the Qobuz App and to login via the Qobuz website.
Have had to change password on my Qobuz website account. All working fine now. Let’s see if this one stays logged in!
Hi @fotobrooks
We received an internal memo from Qobuz that they had done an internal update on their system and some users may be affected to login. I hate to say it, but I think you are one of them!
Anyway, sounds like you are all sorted, but wanted to clarify that there is nothing wrong on the Naim side, just some Qobuz purple smoke due to a recent change.
With regards
Steve Harris
Software Director
Naim Audio Ltd.
Thanks for the info Steve, changing password was the solution. Now going back to to sort out the TV as it seems to have lost iPlayer/ Channel 4 and ITV Hub apps! Don’t you just love technology…!
