Qobuz logon problems
Hi
Is anyone having issues logging into Qobuz since the recent upgrade?
I have changed my password and updated the mandatory fields on my profile, but I am unable to logon via the Qobuz iOS app or on my NDX2 - invalid user ID/Password
Logon via a browser works fine - used this to update the mandatory profile fields.
Clicking on the Qobuz button in the naim app does nothing
I did it yesterday without issues at least.
No issues here.
IIRC the advice previously is to delete the Qobuz app, switch off the control point completely, login via a browser, change password and save, then reactivate Qobuz app and once working, then re-enter your details in the Naim app.
edit - check your last payment is still current!
I just tried to login on the ios ap on my ipad, and got “an error has occurred please try later “
By killing the app on the ipad and then restarting the app I could then login ok.
I assume you are referring to the Qobuz app?
Yes the qoboz app. And its the current app as I updated it a couple of days ago and checked the connect feature, which only listed my lg tv as a potential end point.
Also just tried the qobuz button in the naim ios app when connected to my nd555, and no problems at all accessing that route.
Thanks for the feedback, restarted the NDX2, and was able to log in again, all working as it should now.
Successfully logged into the iOS app as well :slightly_smiling_face:
Interesting that they both work now, makes me wonder if it was something at Qobuz end.
Same problem here. Set password at Qobuz.com, but the app won’t recognise the password and neither will the Naim app when I try to login to Qobuz.
I can login to Qobuz using Facebook but then can only Google cast.
Deleted and reinstalled Qobuz but that doesn’t help either.
Very frustrating.
I had the same problem today tried the usual resets and uninstalling apps many times with no joy. Reset the password to my original one again and still didn’t work so just left internet radio playing for some time the when I checked later Qobuz was back up and working fine.
I’ve had some login problems in the past when I tried to copy and paste email/passwords into the empty boxes and it didn’t like it. Strangely when you type in the information it logs in fine, so give that a try.
It seems to be working for me this morning. Clearly I just needed to be patient!
My experience was similar, successful logon after a period of time, with no changes on my end. Maybe there is a lag in synchronisation of credentials in the qobuz infrastructure.
After updating firmware to 3.11.0 on my AtomQobuz told me I needed to log back in after a major update. I was unable to log into Qobuz last night after many attempts, changing passwords, etc.. This morning about 15 hours later I was able to log in with no issue. If you encounter this issue and have used your correct user name and p/w, just wait.
My issue is slightly different.
In order to use Qobuz via the Naim app, I have to log out and then back in. This works for about two hours, then I have to repeat. Slightly annoying.
I think this started with the whole QC rollout.
I’m struggling to see the compelling evidence for QC, so I tend to use it via the Naim app. But right now, it is a PITA.
The Naim app is clearly not logging me in correctly.
I have raised a ticket with Naim support. But based on previous experience, I think I will need to call them. Otherwise, they never answer.
