There are speedtest apps for IOS. However it may not be a true reflection, depending on your wifi speed.
You can use an iPad – same website speedtest.net or fast.com or https://speed.cloudflare.com - they all work. But be aware that by using WiFi you are subject to interference, poor config issues etc. But at least you’ll get “an indication”. Wired is always better because it has so little that can disrupt it (but it’s still possible…bad wiring, cable, switch etc just a LOT less likely).
You might want to see if you can get service from Bell, Cogeco or TekSavvy, or one of the other 52 (supposed!) ISPs in Windsor and see if one of them can actually get you better service.
