I thought of that this morning but haven’t had time to do just that (work and all). Good suggestion, though. Will report back.
from my side, for example, no problem streaminq Qobuz via BlueOS App on a Node 2i. problems occurred since when I installed ND5 XS2 and Naim App.
Just wanted to update:
At about 2:00 pm my time (CDT) yesterday the problem just resolved itself, even before I had a chance to try the Qobuz app. I put on an album as background while working and just let it play, even with the pauses. I noticed after a few tracks it wasn’t stopping/starting and just played through. It hasn’t had issues since. Just odd.
just a short update.
I receive good assistance from Naim Tech Support but the problem still persists (playback stops completely if a song is longer than about 4:00 minutes long). they also did a network scan, result was fine and the suggested me to change some router firewall settings (but I can only turn it on or off).
Finally, the only solutions would appear the firmware upgrade; and I hope it will be!
regards,
Stefano
