Question Wiim Ultra and Asset
I’ve been using a Wiim Ultra connected to my NAS using Asset as a headphone system in my study.
I noticed last week that the Wiim app doesn’t capture all the artists on my NAS (it holds a large database of over 15,000 albums).
Strange thing is if I do a search for the artist they appear.
Seems there may be some sort of restriction on the folder size. Anyone experienced missing data ?
No, with Pro Plus and using either Asset or MinimServer on my NAS. But my collection is closer to 1500 than 15000 albums. I suspect you’re right about a limit to folder size.
There’s a WiiM forum, so might be worth raising the issue there.
Roger
Yes that was going to be my next port of call.
There is quite a decent forum with Wiim. Not sure if many members there will have hit the number of albums you have on your Nas though. The Wiim and the app get regular updates and additional features as you will know.
You might try the MConnect app, as I do, to complement the Wiim.
That is brilliant - Mconnect captures all the artists and connects to the Wiim - well done thanks
If you’re on Android give Bubblesoft app a try, it is one of the very few Android apps I’ve actually paid for!
