Hi all, just a quick question, although I expect it will develop into a deeper one!
Regarding the 282 aux2 inputs - “aux2” (unpowered) and “aux2 alt” (powered)
I understand that only one of these may be used at once, but are they both “live” and ready to use, or does the chosen socket need to be selected via the programming interface, like the av vs unity gain selection, on the av input socket?
I connected a Stageline, powered from a NAPSC, to the unpowered “aux2” socket, quite a while ago now, but never got around to using it.
Last night I decided to use the turntable connected to it, but, upon selecting “aux2”, found no audio signal at all - just silence.
The Stageline/NAPSC were working fine on the pre-amp to which they were previously connected.
Thank you for any help.
Much appreciated!
Edit: Just popped it onto aux1 to double check the Stageline and it works fine.
So it seems to be an aux2 issue…
