Am I right that the Tidal MQA doesn’t work on Naim units? No point in opting for the top subscription if it has no effect.
Also, os it best to utilise Tidal Connect, rather that the Naim app? A downside of Qobuz for me is the Naim app…! Will that be the best option for quality?
Tidal Connect works with the lower tier as well, but moving from Qobuz to Tidal you’ll be limited to CD quality on your Naim gear and missing out on all the lovely hi-res flacs on Qobuz
