attention attention: all Paradise radios in Italy do not hear this morning. Also from Naim Choise no audio on all the various Paradise …
Hi Andrea,
This is a radio paradise issue, their servers are not working. So from:
http://stream.radioparadise.com/aac-320
returns:
no streams available - try https://new.radioparadise.com
One for Bill @ Radio Paradise to give it a quick restart.
Best
Steve
I use ND5xs2, not the PC
You appear to misunderstand, the RP server for iRadio is down, it’s down in UK as well
If you only want to use ND5 & iRadio, then you need to wait until RP (Bill) fixes it.
OK thanks
I have now selected FOLK ALLEY but the title does not scroll when changing tracks. That always remains.
Should be sorted now according to Bill @RP
No. In Italy NO
All RP services are now OK in UK
RP is all good here in the states as of this morning. RP FLAC stream, that is.
OK now
