RCA to DIN Connection
You can use any input, but if you want to record then use the line out on the NAC-N272. Just be careful though with monitoring at the tape end as it could be easy to create a nasty loop if you have the tape input on the NAC-N272 selected at the same time. Probably safest to have only input or output connected at any one time.
Thanks Richard, appreciate the info.
