I’m having a senior moment and need a simple question answering - which despite reading the faq about interconnects I am unclear about!
I wish to connect a non Naim phono preamp with RCA outputs to a din connection input Aux on my SN3.
Do I need an RCA to 4 pin Din interconnect or an RCA to 5 pin din interconnect?
Thank you to whoever clears up my brain fog!
5 ![]()
But I’d use RCA both ends and go into another line input ![]()
My Urika goes into my Tuner RCA
Thanks @Skeptikal
I feel better already!
I gathered as have just read an extensive set of posts from you about this topic… very informative.
I’m interested in this advice. Is this because the tuner isn’t powered?
Give it a go it’s free and very surprising if done properly.
I cancelled my complete system din conversion when I tried it. ![]()
I use rca to rca from my Lejonkleu phono stage to 552dr, works well and it’s not a custom cable or anything
Do like those din covers
I think I’m going to get some! They look really neat
Thanks mate
You’re welcome
Don’t be put off by location they come from a uk warehouse.
Mine did in a few days
Got them on my CDP as well.
Lovely bargain and look super nice fit. ![]()
I don’t use din at all on my pre so going to get a full set I think, even though I can’t see them round the back, keeps things nice n clean
While I have you……
I’m thinking of making some of the mains cables, same as yours, I want to try and neaten everything up. What parts and cable did you use?
Bit off topic I know
Is it the socket to iec or mains socket to block and sockets.
I come straight out the wall socket into each component, I don’t use any type of multi plug thing anymore
Cool here you are then.
Good luck and much better than boutique handbags. ![]()
IEC Leads.
MK tough plugs MK 655WHI
Bussmann 13A fuses
Doncaster 3 Core Rubber Flexible Cable
3183TRS 1.5mm2 Black
IEC Connector c13 10a Martin Kaiser 794
All terminated with ferrules to stop terminal screw pinching split on multi strand.
Brilliant that, I shall let you know how I get on
Hi @Skeptikal
Did you get the RCA caps/covers from the same person?
Thank you.
Roger.
No they were an easy find on the bay.
The din caps took a bit of sleuthing size etc.
RCA Dust Caps
Item
313674743034
Great advice, I built a set recently using your components. Took a chance and shortened the cables though to avoid slack and floor contact. I can’t discern any SQ difference
