The 35XL boxes are fine for LP storage, strong, stackable and with robust, clip-on lids. I used them for long-term storage and when moving house. When full, 50-60 LPs, they are very heavy and not easy to get into a loft without some strong muscle-power!
Until I bulk up, think the 19L boxes are for me ![]()
More easily managed, no doubt. You will however need a lot of boxes to accommodate up to 500 LPs and they’re not cheap.
Sorry for the thread drift, but I do like the unit that your system is on, who made it ?
Many thanks
Ian
Hi Ian,
This large coffee table came from a local furniture shop.
The shop used to be the front of a large woodwork manufacturer workshop, I got a lot of pine bedroom furnature made there but now they just sell solid oak things from China at about half the price of their own pine, so no competition!
You can probably pick up identical units from anywhere.
To answer your question of who made it, the answer is probably a Chinese robot.
Thank you, if I move ( subject to a lot of thoughts ) I will make some changes to my audio and your table is the type of unit that I want , ie it will take two units like a streamer side by side and with oodles of space
As an interim step, I just bought 4 of these:
Folds together in about 90 seconds. €9 from Amazon. Not bad. Holds 50+ 12"
