A few months ago I purchased a new Rega P10. The cables and RCA connectors seem to be identical to those on a new P3, and not the upgraded cable and locking connectors.
Has anyone here recently (past few months) received a P10? What are the cables/connectors on yours?
I think Rega changed their cabling with the move from the Couple 2 (which when fitted to the turntables had the locking connectors) to the slimmer, black Couple 3. My newish P6 has the black phono cable which is indentical to the Couple 3 cables I use in the same system.
OK, good! So they did make a change. I don’t mind the non-locking, but there is more than a whiff of cost cutting going on here on their former top of the line table. I wonder what connecters the Naia has.
Not sure it’s just about cost cutting, if at all. In my experience the locking connectors could be prone to causing a bit of hum if not perfectly tightened and I don’t think there’s actually any real sonic benefits from using locking connectors. In any event I much prefer the simpler non-locking ones.
