For those with new-ish RP3s and RSs, what cartridge and phono stage options are you using? I’m unboxing an RP3 with an ND5 shortly and will most likely connect it to a Rega PS at first. Fono MM MK5.
Wondering what other combos are out there and the sound signatures between them.
Rega to Rega is pretty straightforward, but guessing theres a number of forum users with a Stageline or other built in PS. Interested to hear some opinions from those that have 'em. (Regas and opinions )
Hi,Maury, my RP3 isn’t new-ish, but I’m using a Nagaoka MP110 body {still have stylus, in case) with a JNP200 stylus, which work well together, but presumably not quite as good as a full MP200, and into an Arkless -modified CA 640P phono.
Very happy with the results, good luck with your search.
I recently sold a P3 for a P6, I think that’s what you should do, the gap is very important and keep the Fono mk5 which is very good… then I replaced the ND5 with the ND7 and now I don’t touch anything!
Hi Maury, After lengthy conversations with my local shops, I purchased a new RP3 RS a short while ago with the ND5 and I’m very satisfied.
I have both Audiolab and Rega io kit, in line with all the reviews I’d read, it sounds really pleasing through both options. No immediate plans for change. Regards, Ian
It was when I bought the P6 that I realized that the ND5 was not fully used with the P3… it is much better on the P6, and as I have already written, the ND7 is really excellent on the P6 and I imagine even better on the P8…
I haven’t compared the Fono with more expensive preamps but I already find it well balanced, no frustrations while listening to it which is essential for me… I think that when the whole channel is REGA there is a consistency that we don’t have without. (as with NAIM in the end!)
P3 with Gold note ds10 and hana eh works well. I also have tried the eh with a naim e board in the nac 62 which is just as effective. I haven’t heard the rega nd carts.
