I know it has been up before. But my problem is slightly different, I think.
Yesterday I found that My ND5 xs didn’t react to the remote. Came suddenly but after 8-12 months without use.
Swapped batteries, cleaned contacts, left it to dry up some 5 hours, rebooted ND5. Pressed aux-I-disp. Turned off and on again after 10 minutes. At first to no avail
But suddenly it worked. No idea why. Actually I didn’t care. Everything worked.
However, today the problem was back. Tried everything again, except for contact cleaning. No result.
Could the remote be faulty ? It has hardly been used since I use the app instead.
Hints to solve it and restore a stable connection would be much appreciated
If you are suspecting a battery or keypad contact problem, as per you cleaning comments, it might help to know that you can easily check whether the remote is actually sending an IR signal simply by looking at the IR transmitter “led” through a mobile phone camera, whilst pressing buttons on the remote.
Most mobile phone cameras will show the “invisible” IR light.
What (right now) annoys me the most is that I dont know what the problem was - and that it reoccurred after some hours the first time it came back alive.
but a nice tip to see it the problem llies with the remote or the streamer.
