Some advice please, the remote for my SN2 will only operate remotely the volume and balance functions. All other options such as input selection, display etc will not work. Thanks for any suggestions, I have changed the batteries so they are good. Thanks.
Try pressing Pre then the number of input left to right 12345 etc.
If you press pre then disp the lights go if until the remote is used.
You have to tell the remote what it is controlling.
Brilliant - success. I had tried that but also changed batteries, did not work, tried your idea and it worked. I guess a fat finger had pressed the wrong button. Thanks.
Exercise your fat finger to my like button.
Glad it’s working now. ![]()
It’s easily done… I’ve certainly been there!
