When i use my ipad to switch to roon and stream on my ndx2, the input on my sn3 switches and i have to use the remote reote to swith it back. Can anyone tell me why this is happening and how I can fix it.
I have found that if you turn off any unused pre-amp inputs in the settings then it will stop flipping from one input to the next. For instance if you’re using the streaming input on your SN3 then only have pre-amp 3 turned on within the Naim App.
Having said that; sometimes my SN3 flips inputs when i fire up my laptop to rip CDs ![]()
Thank you. It worked!
