Apologies if this has already been covered. I normally use and subscribe to Qobuz but signed up for a free Tidal trial just to see if I preferred it… I don’t. At this stage I will stick with Qobuz and won’t use Tidal so I want to remove it when I open the Naim app and am choosing music as it’s linked in the app and seems to be the default go to…
Any ideas how I can remove it from the app? When I choose music I would like the links to Tidal options removing. I can’t find any obvious help in the settings or on the Tidal app. Any help appreciated.
Many thanks,
Jon
Have you logged out of Tidal in the Naim app?
try Input settings/Tidal/Logout
Or deactivate the Tidal Input.
Thanks for all the replies…. all sorted. Much appreciated
