While cleaning one of mrs deeg’s lps today I noticed some gunk on the lead-in groove which would not lift off using the rcm. A check of the inner slip cover revealed she has mended a split with sellotape and I’m thinking that with time some of the adhesive has contaminated the lp edge.
Any ideas on how to remove it as i dont think wd40 is a good idea nor is running a stylus through it when played.
If it’s genuine sellotape type of tape - i.e. not one of the more recent more plasticy types, then the glue is usually water soluble and can be removed by soaking for 30 minutes or so, then wiping with a soft cloth with a little detergent in the water.
Its probably 30 years old so think its the genuine original… thanks to the tip… will give it a go…
Theres not alot after the pass through the rcm so hopefully will lift with a good soak.
I would try isopropyl.
Yes, some cleaning fluid with perhaps a stronger Isopropyl alcohol concentration should do the trick here.
White spirit will dissolve it completely then wipe dry with absorbent kitchen paper.
No it doesn’t effect the Vinyl.
Thanks for the tips peeps… an hour’s bathing the relevant section in some water and record cleaning solution has lifted the gunk and all is good.
