My primary music store on my Uniti Core has become very disorganised with duplicates and incomplete metadata. I cannot find a Naim recommended utility which will help with music catalogue reorganising which preferably can run on the Core. Maybe there is a pc based solution which supervises the Uniti on my home network. Suggestions please?
The only interface you can use with the Core is the Naim app. The relatively limited options it offers for metadata management are all you’ve got to work with.
The exception to this is the Downloads folder, where you store any files not obtained by ripping CDs. You can access this via a computer and do whatever you want to it. One possible option would be to move all of your CD rips from the Music folder to the Downloads folder. You can then do whatever you like to them.
As a Unitiserve user I soon found that storing my rips in FLAC was the way to use and manage them in a flexible way, so I converted all my CD rips from WAV to FLAC. On the Core this option, bizarrely, is missing, and SongKong is, in effect, a workaround for that omission.
