Replacement NAP 140 rotary switch
Hi all,
would anyone know if the rotary power switch from the NAP 140 is available as a spare part, or if there’s a suitable replacement?
Thanks!
Crawford
Is it the knob or the actual switch? Is it a “Chrome Bumper” or an Olive NAP140? If the former then I know Naim don’t have any more knobs and I’ve seen them sell for pretty crazy prices on places such as eBay.
If Olive, Naim may still have the knobs, but perhaps @NeilS will know for sure…
If a switch then probably Naim can repair it for you - you should take it to your Naim dealer who can arrange for you with the factory.
Thanks, it’s the actual switch, knob is fine :slightly_smiling_face:
If it’s for a chrome bumper, we have the switches.
Olive is a different story, the switches were bespoke & are now unobtanium. So “fettling” would be needed to make the chrome bumper ones fit. Namely - the switch shaft is larger in diameter, too long & the flat is at the wrong orientation.
Neil.
Thanks! So can they be bought or is it return to base?
Naim don’t sell spare parts. Your options in the UK are return to Salisbury via your dealer, or Class A in Sheffield.
OK thanks for the info, new to this!
