My system is a CD3, 92/90 and flatcap and the now deceased Royd Doublets.
I’m looking to replace the Royd’s with something with a similar sound. When I first bought the system I found them to be much less “aggressive” than something like the naim intro’s, but still retained a lot of the musicality, detail and presentation.
I’ve done a bit of searching to find recommendations for replacing Doublets in a Naim setup. But unfortunately many of the brands (such as Neat’s) don’t appear to be available in New Zealand.
Looking around the local HiFi stores I may be restricted to the following brands:
Totem
Rega
Fyne
Monitor Audio
Sonus
ELAC
Yamaha
I’d love to hear any suggestions or brands/models I should go and demo. Budget would be around $1200 USD / £900.
I certainly would, but the second hand market but unfortunately its a pretty limited from what i’ve seen here in New Zealand. So pickings would be slim
Fyne F501’s were mentioned to me, before I bought my pre-loved Kudos X3’s.
Kudos also made an X2 - bit less money, but similar size & look, I think.
Speaker Trivia. Kudos X3’s are a similar size (bit bigger) to Royd Doublets, which are a similar size to Linn Kan’s on Kan II stands… All of which… I have owned.
There is distortion on one as soon as the volume gets above very low levels, due to one of the speaker cones becoming detached/damaged - attempted to get them repaired, but to no avail.
