Hi, James, thanks for the suggestion.
I use the 120 to power up the NAC12.
I’ll have a go at anything.
Then it should power up the 282 via a Snaic4. Worth a try to give you some more trouble shooting options.
Cheers, James.
Yes, good idea from James. If the NAP120 powers your NAC12 it should also work with your NAC282. Just remember to fit the link plugs in place.
