Ripped CD info not pulling through
Hi folks
I hope you’ve had a good week.
A request for help please. My Uniti Star is connected to the web, streaming radio works and I can see it on the app. However, I’ve just tried ripping 4 CDs. The new Prince CD and 3 from Jon Batiste, so not too obscure. But, when they’re in and playing or ripping, I just see CD, Track 1 and nothing else. The usual reason is that it’s not connected to Qboz(?) but I can’t see why. Can anyone offer any suggestions on why it’s not picking up the data?
Have a great weekend
It might be as simple as the Star needs a reboot. Try unplugging from the mains, leave it for a few minutes, then plug it back in.
Failing that, I don’t know what to suggest.
Just enter it manually , and download
or photo the cover
Thanks @Blythe , the old magic of turn it off and on again never wears off! I’ll give it a go. We’ve had a few quick power cuts in recently months which may have got it in a muddle
@Proterra thanks, last resort!!
I had ripping issues with my Core recently, and the solution turned out to be using a manual rubber air blower to ensure the laser was clean/unobstructed. May be worth a go.
Thanks @learningtofly that’s interesting! You’d think that would cause other problems as well!! the Star has a slot for the CD rather than a tray so it kept be hard to see let alone get a blower in!! Just back from the dog walk, I’m going to try the original suggestion of the plug shortly!!
Stay tuned everyone…
Update. Power off and back on again. No change. I’m going to try a CD I know has ripped properly to see what happens, and I’ll give the CD port a bit of a puff.
If anyone from @admins has any thoughts they would be very welcome
I’m quietly confident.
That quiet confidence was sadly misplaced @learningtofly I have it a good puff all along the CD insert. All the internet services are working absolutely fine, but no metadata is brought forth
Oh, that’s a shame. I guess it was worth a try though.
Have you tried Naim support (they’re incredibly helpful)?
Yep that’s next on the list. I’ve used them before with problems and you’re right, they’re brilliant
Fingers crossed.
They might suggest a factory reset.
The power user version of turn it off and on again @Blythe !! Let’s see what they say. When I first got it, it could see my NAS and something odd like it could see MP3 folders but not the FLAC one​:person_shrugging: and we got that sorted so I have high hopes!
Have a good week folks
