Roon 1.8
On iOS phone do you still have bookmarks available?
Yes bookmarks still here
I’d that tablet ? I am looking at phone. Nice album by the way.
Can’t see bookmarks, but not sure I’ve ever even used the feature!
Ipad. Ah maybe thats ipad ios, its different?
Just clicked on browse by genres and it crashed.
I dont use bookmarks or focus or playlists or … lots of features. Just find an album and click play.
Just found it on iPhone using the 3 horizontal line thingy top left:
Thanks , yes it’s there they moved it. I use them a lot for albums artists I play a lot. Now it requires an extra click. :roll_eyes:
Portrait on iPad :slight_smile:
Is your IOS-device set to german? Try changing to english. That stopped the crashing for me.
roughly how long are you waiting for the update to DL and install guys?
At first the download took forever on the Mac Mini. I decided to reboot the Mac mini and give it another go. The download then took 30 seconds, the install a few minutes and the database update 5 minutes or so.
Glad that worked for you. Not so much for me. :frowning:
What do you mean by changing the language on iPad/iPhone to English? I cannot change the language of Roon on the iPad/iPhone, because I cannot enter the settings. Or do you mean the language of the iOS?
Thanks for help!
Yes, language of IOS! not roon.
Worked fairly well for me. App first then I had to close app and start it again to get the NUC download to start. Under 10 mins in total. Quite like the portrait mode.
Thanks. It works, but that is not really a good workaround for me. I am used to use German language setting on the iPad. And I am wondering because on my iPhone Roon does not produce crashes in German language setting.
Interestingly though, note the equally irritating purple circle top right with an initial:
Are profiles new? I assume I could create family member profiles - that would be cool and make the ‘Hi Whoever’ thing pertinent!
Click on it:
Similar to others here: took two attempts. First hung around 50%; restarted and it went through quickly plus db update for a couple of minutes.
I recommend backing up current setup before updating anything: v1.8 clients cannot access v1.7 core.
Is there a way to restart the download on the Core (Rock)? Seems stuck at 40% forever
No they have always been there and it’s always had the Hi bit on the home page since forever it’s not new at all. All it does is have a seperate play history it mostly pointless as it currently stands though.
