Roon - gapless playback
I’m not sure gapless is the term I’m looking for; therefore let me explain the situation.
I use an Audiostore music server with Roon loaded and Qobuz streaming enabled.
Recently, I can’t get past the first track. It plays and then stops; pressing the skip icon moves onto the next track and all is well.
Any ideas how to overcome this?
This sounds like when you press play, it is adding 1 track only, rather than the whole album.
Have you changed the play actions options? (Though i think this is just the options you can choose, rather than the default behaviour).
Yep these are checked.
I’ll give it another go today. Thanks for the suggestion.
Still a problem … perhaps the fault lies with Qobuz.
Is it adding everything into the play queue? In which case it would be more likely that the fault is in qobuz not allowing the next track through for some reason.
There are roon logs you can check which might indicate what’s dropping.
