In cases it helps others, a note that for NUC10’s at least (and maybe others) you also need to disable Safe Boot in the BIOS for it to work, otherwise you’ll spend a fun few hours using a variety of tools to flash your USB drive, search for another USB drive, make USB the first bootable choice, and all sorts of other ‘fixes’ that aren’t…
It’s an omission from the installation instructions. They have been updated a while ago to talk about enabling Legacy Boot, which is needed, but that’s all clear. Just untick a box and you can save yourself, oh, hours…
