Simon, can you say a little more about this?
But you would acknowledge presumably, a house hold fridge, lighting, tv, electric supply (if indeed this network interference can be heard) will have a far greater influence no?
It sounds like we are discussing a needle in a haystack of potential noise interference.
If it really does make a noise the obvious conclusion is to use wifi and make this area of the network the best that it can be.
I suspect this is ignored because there is nothing shiny to look at such as multi thousand pound last metre ethernet cables
What is your opinion on putting a switch on some rubber feet to āimprove sound?ā
The slightly condensing tone of āit system dependentā, i.e. āperhaps your system is not very good and resolving detailā does not help the conversation
My only conclusion is that for those that genuinely hear a difference at this minute scale, probably donāt enjoy music much, the recordings must sound terrible, what with the noisy environments of those recording studios
Well, thatās the way you understand it, or wish to understand it.
What about a walk and some fresh air?
At no point did I say ādigital is digitalā
What are asked for if there is an assumption of ānoiseā, how does this noise manifest, is it more or less than say a fridge on your mains?
If an hifi company introduced an audiophile fridge, reducing ānoiseā would you purchase one?
Whatās are the measurements, what are the effects, how do the measurements Effect sound to our ears, is it peer reviewed?
I have been in the fortunate position of checking out a variety of products over the years, one thing that has universally baffled me is the last one metre of (insert cable of choice) making the blind bit of difference. And to date as far as I am aware there is no actual peer reviewed evidence that they do. All we have is, āeven my wife heard the differenceā and a bunch of blokes selling expensive cables to a bunch of other blokes.
I am far from stressed, I find it hilarious. Back in the day naim never fell for this crap either, but obviously an accountant got involved somewhere.
WiFi receivers introduce noise too. If not a lot of us could have saved a lot of money.
Personally I would be very happy not to invest in expensive switch,linear ps and ethernet cables. And WiFi looks better too.
I am not shouting.
This is a forum, where, within the rules of the forum we are allowed to express our opinion. Evidently all you are after is an echo chamber. If Richard wants to ban me he can, but as far as I am aware I am expressing a valid opinion just as you are, I have been rude to no one.
Please if you could offer me a search term for google that will lead me to the peer reviewed evidence based testing that took place, I would be really interested to watch that, (genuinely).
Then the answer is simple, revert to CDs!
SQ is as a butterfly, which, when pursued, is always beyond our grasp, but which, if we sit down quielty, may alight upon us.
With apologies to Nathaniel Hawthorne ( 1804-1864 )
Tired of all this chatter and tests and especially of the swich brands I stopped on 2 Cisco Catalyst 2960 CG (yes gigabytes, the white ones with 8 ports!) And the sound is fine. Oh my God it is also fine with the wifi of the airpory extreme apple.
The Chord Unicorn.
Now thereās a new product development concept.
In case anyone is actually thinking of cutting ethernet and hifi system EM noise from your router on a budget, Iād say, yes, do it, get an iFi iPower plug of appropriate amperage and voltage.
I think you can return it if not satisfied.
It works for me and also for NigelB.
I think they just brought out a newer version than mine.
One thing to watch - you may well need a connector to add to the end of the plug so it fits your router socket.
There are some in the box that come for free but they didnāt fit mine.
I bought a set of about 18 cheap ones off tābay.
But if you find out the pin/hole sizes that your router requires you can order a posh āaudio qualityā plug adaptor IIRC from iFi or similar.
Or hide router, switch, Ethernet cablesā¦
Yes, hiding from problems - that usually works!
[quote=āgaryi, post:54, topic:11664, full:trueā]
I am not shouting.[/quote]
Nope, youāre not shouting - more like continuously grumbling this pedantic argument thatās been rehashed over and over again, and obviously no matter how many long screeds you insist others must write in order to try and convince you, thereās probably nothing that will change your mind that cables etc. will make a difference, despite thousands testing and hearing otherwise. Apologies, Gary, but it just gets boring, even more boring than you feel the āecho chamberā is to you. A number of years back this was new fertile ground for debate; streaming hifi has moved on since then and at this point itās pretty much incontrovertible that networking gear will make some, if not major, changes to the sound, for most (though not all) setups. The only way to not be an afraid ostrich, is to roll up the sleeves (and pull out the wallet) and try for yourself. Iām so glad I did, but because doing so has utterly transformed the basic V1 Iāve been rolling with the last ten years.
Totally hear you, but tell me, what else have you undertaken to improve your dac? Turned that fridge off?
Do you concede it can be taken too far? Do you think spending say 1k on 1 metre ethernet lead is worth it for the perceived benefits it brings? (Rather than say putting that money towards a better dac)
Fear not, Iāll leave it at that, leave you to it as it were.
No the point I have made a number of times is I have tried. Many times over the years, ethernet cables, power cables, usb cables, you name it.
I do not hear a difference. Happy to agree I have bias as well, luckily not bias created from paying for said cables. Its why all I have left is āshow me the evidenceā. Otherwise all any of us can do is caveat our definitive statements with āin my opinionā (me included)
Iāll also be up front and honest and say I am a bloke I like the shiny, nice cables look nice, who does not want them in their system? But sound quality is has not been one of them for me.
I have also paid far to much for my network set up. It certainly would have been nice to say it made a difference to the hifi but again, I could not say, honestly I dont believe it did.
I do hear differences. For me the most fundamental changes in this modern world come from the streaming platform.
Its all down to preference of course, but for anyone with Roon and an Async USB Dac, I would highly recommend creating a streamer from Daphile, an exceptional piece of software and donationware to boot.
Yes, I too bought a pack of cheap adaptors on the river and found that I had to stack a couple to get the right sizes to connect the iFi iPower to my BT Hub5.
Worth it (I think).
Why would I turn my fridge off? I have two dedicated lines (albeit not a dedicated CU), and those have power conditioning. I donāt think you need to spend one k on an ethernet cable (Iāve never spent above $60 on an ethernet cable - and that one is going to be sold) - though neither do I believe one needs to spend $1k to tell time (which reminds me my $5k Seamaster needs to go in for repair). I spent $99 on a Shunyata Venom USB cable recently and that made a huge difference to the V1 - as well as a new power cable that I saved $ on by assembling the parts myself ($125 total), and a couple of AC iPurifiers at $100 a pop to clean up the power and add surge protection (for both V1 and the 160).
(this is not mentioning the oR and oM bridge and other various network tweaks before all that).
I think you are perhaps confused by value vs efficacy.
The iFiās come with adaptors. Those didnāt work?
No, they didnāt fit my PlusNet router.
I just used one adaptor on the end of the iPower.
