anybody know where i can purchase a hd download of the album, i can only find it on cd or cd quality on qobuz.
not sure i want to spend £135 on a copy on vinyl from the usa
Don’t know if you’re after any particular recording, but Presto Classical has a number of Hi Def offerings. I have bought many times from Presto and I would recommend it.
was after, Kyung Wha Chung
will check out presto, thank you
still cd quality
Why not try one of their other 96/24 offerings?
i have now, thank you.
think i will also end up with the vinyl
Another fan of Presto here, they have several different versions on high resolution
The original Decca vinyl was excellent and should be fairly easy to buy. I think the last (mint) copy I bought was about £2, admittedly 20 odd years ago, but can’t have gone up too much since then.
Edit: Just looked at Discogs - wow. I would wait a bit and see what crops up elsewhere…
Crazy, i know, £190 for a mint copy is the most expensive i have seen.
This is available as a 24/96 download from Chandos themselves and no doubt other sources. It’s a good recording and the other Saint-Saëns pieces are worth a listen, too.
Roger
PS Should have said it does include Dance Macabre.
