SBL / M8 spikes
Hello everybody,
I am currently looking for high quality, sharp M8 spikes
of 40-45 mm lenght for custom steel speaker stands.
Actually Naim SBL spikes would be perfect for this, but
it is pretty hard to find them without buying a pair of SBLs :-).
Would you have any advice on this?
Thanks in advance,
Ebay and Amazon will have what you need - thousands of options. I bought some recently for the rather corroded ones on my NBLs. Indistinguishable from the originals except for the lack of rust!
Not hard to find. Assuming you’re in Britain, try Wilmslow Audio, Falcon Acoustics, HiFi Collective, and probably also CPC & Farnell.
If you can, think about having only 3 spikes per speaker/stand.
3 is a “milkmaids stool” it won’t rock.
I have three spikes on my own custom built speakers, 2 at the front are used for side to side level adjustment, it’s just so rockless solid.
Go to your local dealer and see what’s on the speakers he sells. At least B&W will sell you spares, so you could try those, but I’m sure many other brands will as well. Just need to find the ones that suit you.
Thanks for the tip, sounds promising
Thanks! Do you have a reference to provide me, maybe?
Another good example of “where are you”
Martin
