I’ve searched for answers on this & other fora but not found anything - possibly the questions are just plain silly
Whats the best way of getting the speaker cable into the crossover? That is, the routing of the cable - is it correct to feed the cable under the metal frame & between the frame & cabinet? Thus allowing the SBL to be closer to the wall?
And do SBLs come “handed” - i.e. right hand/left hand speaker?
You can tell my systems with Darran being serviced - bored & thinking of stuff to do when it all comes back
When I had mine, this is what I did. I made a tight loop of Naca5 under the frame. The SA8 end then came out of the rear and rose vertically to meet the crossover. I reasoned that it put less strain on the soldered joints in the crossover (and possibly the SA8 pins) this way.
You are right, you will almost have the frames touching the skirting boards this way.
