Searching within Qobuz
i listen to Qobuz with the Naim Atom, and Muso. Also through an Innuos Zenith 2SE streamer. Search results differ between Naim and Innuos platforms, which is so so annoying. For example, searching for CAT STEVENS on Naim, revealed nothing, other than a playlist. The Innuos presented the full range of albums, individual tracks, and several plalylists. Why should this be so?, is there some obscure hidden setting that will (or does not) allow Naim to reveal all?
b.t.w. - all firmware is up to date, and iphone15 used to search - also up to date.
I’ve just searched Qobuz in the Naim app and get this, plus what looks like hundreds more. Make sure you tap the magnifying glass at the top, rather than using filter, which I suspect you may be doing.
Thanks, noted and reassuring, I habitually use the search button on the keyboard, on all searches, which maybe why results differ, or not.
This is the same on Tidal - there are two different search options. Have to use the main one on top
Is your MuSo second generation? If so, why not use Qobuz Connect? That way you’ll have a common interface for your Naim devices and (I think) your Zenith streamer.
Roger
Qobuz have also introduced multiple search options, if I have understood it correctly!?
There is a “professionally curated” option and another one I have already forgotten!
To further complicate matters, there’s also a third option that appears to be options 1 and 2 added together!
I saw a pop up notification telling me of these new additions.
I read it, very briefly, then dismissed it.
Now I cannot recall what it said!
Perhaps a more attentive Qobuz user could remind us of these options!?
