A couple days ago I moved my NDX2 to my main system and put my ND555 on the Supernait 3. I don’t do any serious listening on the main system with my digital source, only with my LP12. The ND555 sounds good with the supernait 3 but am thinking of maybe moving to a NC 250 and partnering with a source that can just go to an amp. That of a Bartok or Rossini. I think to really get the most out of my ND555 I’d have to get separates and trying to keep a box count down in my second system. Any other suggestions? Maybe a D’Agostino or Burmester with a Bartok? I’m driving Wilson Duette’s in the second system. Thanks!
I guess the obvious choice with a 250 would be an NSC222.
I don’t understand. You have an Nd555 with 552/500 and Wilson speakers, and Ndx2 with Supernait, but you finally put the Nd555 on the Supernait and Ndx2 on 552/500.
Why?
I did wonder too?
I think you need to have a rethink,and move some items on such as the nd555 or ndx2 and buy perhaps a new system like the new 200 or 300 series?
As has been suggested, it may be worthwhile putting your ‘best’ streamer with your ‘best’ amp.
If you’re looking at a change, a Rossini Apex comfortably outperforms both the ND555 and the NDX2. I run one with a D’Agostino amp, and the results are stunning.
Yes, a bit odd I guess but here’s what I’m doing. The room in my basement is for my second system started earlier in 2023. I have 2 young kids and rarely get quality time to listen to the main 500 system. When i do, it is spent with my LP12. There is always music on in the house though and that has been with the ND555 until I just put the NDX2 in that system.
When I get downstairs to the second system it is dedicated listening but on a smaller system in a smaller room. That source is an ND555 now with the Supernait. I would either keep the ND555 and find a better integrated amp to run it into or switch to a new digital source that can run directily into an amp. Hence the Bartok/D’Agostino option?
Or, the other idea to still keep box count relatively low is a 250 DR into maybe the new Naim 332 preamp to keep the ND555.
Thanks @Andyblain Are you running the Rossini directly into a D’agostino amp without a preamp? wshich amp do you use?
That is a beast! I’ve seen one before and thought about this as well. There is a used D’agostino s200 for sale nearby that could be worth a try. If I switched to a new source, I may have to just start with a Bartok though as funds don’t really permit for a Rossini.
This set up. The Kurtis out on whether it’s better to use a dCS app directly into a power amp. You need to listen with your own ears to decide what you prefer. But, dCS is quality equipment.
Commented on your thread on the other thread you have started
