As good a thread as any for this post, which is simply to raise awareness of the benefits of adding Naim ampflication to the ‘b’ stereo system…
This is a bedroom setup (briefly was using a Sony SXRD projector on the wall, and justified having a surround sound music setup to go with…), using a 55" OLED around 4-4.5 metres from the pillows…
The setup inherits a huge selection of ‘b’ speakers, but also has one of the best speakers in the house, the centre channel (in the photo, but ‘dark’), whose tweeters are $130 each, and the crossovers ‘top tier’/expensive… etc…; nice jarrah and matching the surrounds…
The heights are mostly centre channel speakers repurposed (large ones with front porting, generally from the 6-800$ price tier per centre speaker)…
When I added the Naim integrated amplifier, in AV Bypass mode, to the Anthem MRX720; the resultant sound upgrade was SO substantial that it made me reconsider our ‘house-fi’.
Part of the upgrade was simply removing the burden of the front left/right ‘mains’ speakers from the surround amp, leaving a larger power reserve for the remaining speakers. Dynamics massively increased, and sound quality was dramatically improved, certainly during dynamic and loaded soundtracks.
So I upgraded the amplifiers in the Anthem MRX to using a twenty year dated Marantz surround receiver… (simply as ‘power amps’).
This noticeably improved the sound quality for the surround channels, and only the centre speaker remained on the Anthem…
Listening for the last week or so, revealed that only the centre channel speaker was strained/‘holding back the system’ (and we listen at low to middle volume levels nearly always, so not a ‘volume thing’)
So, missing the quality the Naim amp had given to the front mains (used in surround tracks to setup the sound before ‘steering’), today I quick ‘hodged podged’ the Naim in place to see if it would help further, over using the Marantz as ‘outboard power amps’.
Big “YES”!
The Naim integrated, in AV Bypass mode, adds so much to the setup, that it will now be reincorporated to the surround setup, and centre channel speaker can go on the outboard power amp, and the Anthem will basically act as a processor (rather than an integrated amp, it will be a ‘preamp’).
For the last month, listening to ‘soundscapes’ has been enjoyable.
As of today, I am happy listening to actual singers and ‘bands’ again.
The Naim helps the timing and location of audio cues SO MUCH that the smallest nuances of echo and decay have really opened up the soundfield…
not just for prerecorded sounds “out there” phase effects etc, but the ability to place beyond walls and truly feel like I am in a room where an orchestra can play 50 feet beyond the screen is exceptional (and akin to what I would hear in the nineties via a Yamaha DSPA1000 and a well setup room).
achieivng the quality of audio that surround sound gave when it had to compete against ‘quality two channel’ is no easy feat, and something lost to the sands of time, it would seem… (unless spending five figure price points on ‘modern surround sound’).
A Naim amp in AV Bypass can easily raise the tier of sound quality experienced, and probably do so at a small fraction of the price to do so by upgrading a ‘modern do everything big box’ (master of none/‘jack of all trades’ part).
adding a dedicated musical amp adds so much… and spec sheets don’t even suggest it is possible/‘a thing’; so ‘word of mouth’ from a person who has been doing theatre installs for decades, and toys with this stuff daily…
AV Bypass ‘for the win’.
