Seems that without Hi-Cap is better sound in my System
Yes - you can’t use the housing of the PSC plug as a reference, it is isolated.
Just measure between the two pins - should be 16VDC for the original version.
Neil.
Hi Neils
Great, Thank you for letting me know this.
My napsc shows the 16.5 v
1: postivie 2: negative is this correct ?
Thanks.
As you look at the back of the 82 - the lower pin is positive.
Neil.
