I am looking at new phono stages and one of them, MM, will only give 100mV out with my 1mV cartridge.
The MC type from the same manufacturer will clip because the gain would be too high.
1mV is very low for a MM cart - more like High Output MC. Some valve MC phono stages that don’t use transformers may be OK here as they can’t have too much gain otherwise they get too noisy. Note that the Stageline or Prefix E are ideal for 1mV, although you may be after something better still?
The SN3 spec states that the phono stage is built for 5mV MM cartridges. So I have not tried it and would want a more versatile phono for future proofing.
As far as I am aware the Grado phono is no longer available, it is not listed on their web site.
